leak? I'm not even sure this is possible but it's one if the new things added to a good working engine. Even less likely, was a coolant and oil line cross connected during the servicing? One way to verify on the issue -- drain the oil and inspect further that way - visually or by having a sample tested for contaminants. Once you figure out what happened it would be good to post back on the situation. This could help others using search. FYI- this post will lock after a few days so just start a new thread and reference link back to this one.
